question on shocks
Discussion in 'The Garage' started by bryguy00b, Jun 2, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i have a 84 and a 85 blazer..and i was looknig at them..the 84 has dual shocks in the fornt..on each side..two on each side..the 85 just has the normall one on each side..4 totall shcoks..did this dual shocks come stock on the blazer..or do you think the last owner or someone added them?
    thanx-Bryan
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    It was a factory option.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Yes they are a factory option, my '87 has them. BTW if you want to add them to a non dual shock truck the GM part #'s (thanks 6.2L Jimmy!) are 14072699 and 14072700 (you will need both) and they are less than $30.
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    If you wanna convert to duals just buy the bracket? or get the one from skyjackers?
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    If you wanna convert to duals just buy the GM bracket? or get the one from skyjackers?
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    yeah, my 85 had 4 shocks up front from the factory... with shock technology where it is today, its really unecessary... I only run 2 up front now.
    J
  7. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    I think it looks REALLY cool though
  8. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    It really depends on how you use your rig....If you are like me and like to see how high your truck can jump before an axle snaps, dual shocks are a must....But like you say, for most anything else there is no need for dual shock and they will only make the ride rougher.
  9. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Could you unbolt 1set of front shocks for the street and just bolt the other shock on when you go wheelen or would this be to big of a pain?
  10. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Well I use RS9000's, so I can just adjust them to a softer setting on road. Any more work than turning the knob, and I would say that it is too much work. Even if you use a single RS9000 on the front and put it on the stiffest setting, it will feel like it has dual shocks and basically have the same effect at a lower cost.
  11. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ahh ok thanx guys!!..yea when i put the lift in and get the 4 shocks that come wiht it im just going to leave it back to two up fornt.
    Bryan-later
