question on spider gears
Discussion in 'The Garage' started by Impex, Jun 9, 2002.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    will the spider gears from a carrier that has 3.07 (ill call it first design) gears work on the (second) type of carrier that would hold 4.10 gears, this is for a 12bolt axle
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    AFAIK all the internal parts are interchangable in the 12 bolts, the same goes for the 10 bolts, but not between 10 and 12 bolt.
  3. Impex
    469
    Chandler, AZ
    even if its the carrier to accept lower gears
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes, gear case splits do not make a difference. If however you are working on a 10 bolt then there is the difference of 28 or 30 spline.
  5. Impex
    469
    Chandler, AZ
    thanks /forums/images/icons/smile.gif
