Question on steering arm studs
Discussion in 'The Garage' started by Yukon Jack, Mar 11, 2006.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    When I pulled the original steering arm it was a bear and ended up damaging two of the three studs that attach the steering arm. When I install the new studs I know I need to use thread locker on the threads. Do I just get the studs in finger tight then install the steering arm and then torque the nuts or do I need to use double nuts on the studs to tighten them down good and tight, remove the double nuts, then install the steering arm and torque? :confused:
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'd install the studs with the double nut method, that way you can physically see that the studs are ALL THE WAY DOWN and tight.
  3. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    Yep double nut method, thats what I did and then I used a thin vise grip on the unthreaded part and a wrench to hold the bottom nut while I backed the top one off so that I was sure that I wasn't backing the stud out.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Tighten the hell out of them before you put the arm on. Also, don't forget to clean out the holes first.
  5. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    double nut for sure. Also, you might wanna get your new studs from ARP (I got my arps via ORD...). They are pretty much the best studs you can get and aren't exceptionally expensive.
    j
  6. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Thanks for steering me straight, jeez, I just did a HotRod TV pun :eek1: :haha:
    I bought the studs from GM a while back, so I'll just throw those in. Thanks for the advice :bow:
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    a stud installer works GREAT.... ;)
