Question on tapping top cap for hydro assist
Discussion in 'The Garage' started by 8_YOUR_H2, Jan 16, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Is there a specific place that the top cap needs to be drilled and tapped when doing the JKW hydro assist? There were no documents provided to show where the top fitting needs to go. The picture on their website is not good enough to go of of. If any one has the ems or jkw set up and could post up any info I would be gratefull.
    Thank you.
    I have searched and found a lot of info for drilling the actual box case but not the top cap.
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    why do you need to drill the top cap?
  3. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    So you can turn right.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Don't tap either of the aluminum caps. They are too weak and will crack. Tap the cast iron housing of the steering box. I would post up a pic of mine but www.scbd.org is down right now :( Maybe if you bug WillyShaver he will do something about it ;)
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    The top cap is plenty thick and there are a few aftermarket companies for the front cap. That is the cap that splits anyway. If you look on the inside of the top cap there is a small recess on the long side. Center that and you have your spot. I did it about 4 months ago and have been fine, this is on a DD with 40's that sees severe rock use.
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is a crap shoot. I have seen the same thing not last a single run.
    If you are going to do it...do it right and tap the housing. It isn't that hard.
  7. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I have not modded my pump at all. I am sure the extra pressure has a little to do with it. I would love to mod my pump but worry about pump life and can't commit to race parts yet.
