question on tire size
Discussion in 'Pacific Region' started by hd-10, Nov 3, 2004.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    i got a 91 blazer with a 4 inch susp. lift can i fit 36" iroks under it with out a body lift or cutting the finder? if i got to cut the finders about how much?
  2. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    no, they will rub. trim those fenders. I really havent done THAT much trimming and I fit 39.5x15x15 under 5" of lift.
    j
  3. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    did you have to cut the whole finder or just the corners off? also front and back or just the front
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    4" lift, 36" Iroks. The portion by the firewall is the most critical area to trim, that where the tire will rub the most. The front part also needs trimming, but not as much. I also run no sway bar, so that makes a difference.
    Here is another pic http://community.webshots.com/photo/77295930/77296397TJrXoU this one shows where the inner fender was located in realtion to how much of the outer fender was removed. Other pics in that album as well.
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Wow, you can't even tell where you made the cuts at... You must be an expert at autobody.... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  6. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Well once upon a time it looked "ok" but that was a few wheelin trips ago /forums/images/graemlins/grin.gif And I still stand by "it's not my fault" /forums/images/graemlins/wink.gif
  7. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I call B.S. on that one! I wuz there dood! /forums/images/graemlins/histerical.gif
  8. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    look like a lot to cut off. how do you like your iroks? i am getting mine put on on friday.
  9. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I like them so far, but that said I have only been around the block a few times with them, just got them last weekend /forums/images/graemlins/grin.gif They are also big for 36's, they are .1 inches shorter than the 37" Irok radial. Think actual diameter was 36.8". And mounted on my truck at 30 PSI they measure about 35.5"
    Now I just have to get them in the dirt and see how they work where it counts!
  10. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I was running 38x15.50 TSL Radials on a 4" lift. I cut the sh!t out of the fenders and they would still rub the firewall. I think w/ a 4" and 36's you are going to have to do some trimming reguardless if you put on a body lift or not if you plan on wheelin' it very much.
  11. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    If you like that body work, check this out!
    Thats right, got out my "body" hammer (aka BFH) and my super awesome welder featuring .035 flux core wire.....oh yeah, thats precision work there! Maybe I can get a zoomed in shot showing the awesome booger welds /forums/images/graemlins/thinking.gif
  12. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    lol!! well, ok... but compared to some rigs on ck5 I dont have too much. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif here is a pic...
    doesnt really show the front wheel well to good... but you get the point. If ya want, I'll go out in the driveway and shap a straight-on pic from the side so you can see exactly how I did the front.
    j
  13. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    that looks like you did a good job on the fenders. thanks for the pic doesn't look like you had to cut too much off of the front of the front fender mostly just the back. is that right?
  14. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    on the front part of the front wheel well I chopped the "fangs" off and then did a small angle cut on the outter edge. On the rear side of the same wheel well, i did the ck5-standard chop, which makes the outter fender about even with the floorboard behind the pedals. I'll take a good pic for ya tomorow morning...
    j
