Question on tranny hook-up?? Need some help.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevyracing, May 26, 2002.
  1. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I have an 85 Blazer that has a 700R-4 tranny in it. I am putting in a 350. The blazer had no engine at all in it when I got it. The wires for the tranny are just hanging there. My question is this:
    1) what do the wires do?
    2) where do they hook up? (to the engine side)
    3) do I need any sensors on the engine for this tranny?
    I have run 4 speeds in all my other blazers and have never messed with an automatic, especially a 700r-4.
    Thanks,
    John
  2. FOUR PLAY
    FOUR PLAY Newbie
    May 21, 2002
    You don't need the wires. I think they do something for the overdrive. I did the same thing to my Blazer, and there wasn't any sensors on the engine.
  3. chevyracing
    Sep 8, 2001
    2,589
    Colorado
    Okay, thanks. I will try it without them.
    John
  4. dyeager535
    26,975
    You are putting in an SBC 350, not a TH350 right? You will heat the transmission up, and lose mileage/increase engine RPM's while cruising. Those would be the lockup wires. Run it without at your own risk. It can be done, but you had better have an auxiallary trans cooler or you'll pay for rebuilding the tranny later.
    Simple system, worth hooking back up.
