question on wheel bearings
Discussion in '1992-Present Chevy & GMC models' started by 84CUCV, Aug 21, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    I am about to put on new rotors and pads. Truck has 70k on it. so it should be ok to pack the bearings and reuse then right? Second thing, when snuging dwon on the wheel bearings are you spose to go as tight as you can then back of a little put the pin in and your done? that is what i was told anyway. Just want to make sure i do this right the first time. thx for the help as always.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    if its your 98 c 2x4 then if thay look good with no burn spots or gouges and spots missing i would clean them repack them and install with new seals. then snog the nut by hand and line up pin hole.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    just did it. snug the nut? i just made them to tight then. crap thx mike
