question on winch ground
Discussion in 'The Garage' started by BobK, Sep 23, 2004.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Does a winch ground NEED to be made at the battery or can you ground it to the frame.
    I have a 2g ground strap going from the battery to the frame already.
    I'm redoing the route of my winch cables and it would clean things up a little if I could ground it to the frame.
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Right to the battery would be best.
  3. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    All most forgot.........Nice Rig /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree, you don't want that much current bouncing around.
  5. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    What do you mean by bouncing around?
  6. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I think by bouncing around he means from connection to connection and so on.
    To the battery is the best place to ground the winch. A frame makes for a terrible wire.
  7. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Got it,thanks /forums/images/graemlins/thumb.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What I mean by is that current takes the path of least resistance. That isn't necessarily up that bare wire when you've got 450 amps flowing to that winch. That means that current is flowing all over the place on your truck, looking for a path back to the battery. That doesn't even mention the voltage drop on the additional connectors.
  9. ugly_blazer
    Apr 12, 2004
    1,214
    Current will not flow all over looking for a path to the battery as it has no ability to turn around and look elsewhere. It will only flow where there is a potential difference, where it knows for sure that work can be acomplished. If the electrical requirements are satisfied by the framerail there will be no potential difference and thus the current will not deviate from that framerail.
    Would I ground a winch to the frame? No. Not because I fear current traveling all over my truck, but because the resistance created by connceting terminals to the framerail would require the battery to supply much more amperage than what the winch would draw, especially after these connctions become corroded.
  10. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Little bit of a hijack here but just curious how yall got your starter motor grounded?
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's bolted to the engine block.
    A starter pulls about 150 amps though, not 500.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    #1, there is a "potential difference" aka voltage everywhere. Every piece of metal on your truck is a potential ground until either enough current flows through it to burn it up. Ask my how I know.
    #2 We'd like to think that the electrical requirements would be fulfilled by the frame rail but the reality is that the current will find elsewhere to flow.
    #3, With more resistance, LESS current will flow, not more. That is simple ohms law.
  13. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I have my Ramsey RE12000 grounded to the frame and haven't had any problems during winching or normal operations.
  14. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Every vehicle I work on from now on will end up with a battery cable going directly from the battery ground to the bolt that holds the starter on. It makes a big difference in my experience. Hijack off.
  15. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    I guess I'm lucky--I grounded the winch on my trucks crane directly to the frame and it works ok,a bit sluggish perhaps,but its always lifted whatever I hooked to it--I bet it would work a lot better if it had a nice welding cable to both ground and positive--but I dont have unlimited funds for that stuff,especially when it gets used only ocasionally --crazy:
  16. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Besides, I don't know about the other winch companies, but warn will not warranty a winch if both cables are not on the battery. Others might be the same way /forums/images/graemlins/dunno.gif
  17. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    I got it all completed,works like a charm.
    I went directly to the battery.
    Replaced the orig. ground and power wires with 2g welding cable.
    Crimped and soldered on some new terminal ends and that was that.
    Routed the wires out of the way and secured them to the rad. core.
    Here's a couple pic's
  18. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    One thing you might want to Consider on your set up, have you ever seen Batterys on a Electric tow motor? they use a big plug in connector from the battery pack to the power cables. when I get my winch mounted I am going to buy these connectors and install them by the winch. Would be a great thing for saftey in case on an Emergency.
  19. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    That's where my friggin winch went. Ha. Seriously though. looks good. Let me know how you like that model. /forums/images/graemlins/waytogo.gif
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll try it. Sounds like a good idea to prevent voltage drop between motor and the wire.
