Question re: 4 wheel drive light
Discussion in 'The Garage' started by dragon66, Jan 9, 2004.
  1. dragon66
    dragon66 Registered Member
    Mar 4, 2003
    27
    Denver, CO
    The other day while driving my 4 wheel drive light came on in the Jimmy. Pulled over shifted from 2 to 4 hi and then back, light went off. Went to start it and the light went on again. Tried the same thing, shifting and did not work this time, any suggestions? /forums/images/graemlins/confused.gif
  2. lukebaby1
    lukebaby1 1/2 ton status
    Dec 16, 2003
    231
    Richmond, Virginia
    Sounds like your button switch located under the shifter floor cover is either shorted from rubbing against the body, or has come loose and gone out of adjustment. Pull the cover (4 torxs screws) and check it. /forums/images/graemlins/thumb.gif
  3. dragon66
    Mar 4, 2003
    27
    Denver, CO
    Will check it out, thanks! /forums/images/graemlins/thumb.gif
  4. scottnj
    scottnj 1/2 ton status
    Aug 4, 2001
    112
    Central Florida
    My wire was crushed under the floor shitfer plate from the factory. There is a little channel for the wire to run to the tranfer case to the dash. They missed the channel. After 12 years is finally crushed completely and shorted out. Fixed now!! Could have been a bad Monday or a party Friday with that job /forums/images/graemlins/smile.gif
