Question re gasket on tailgate for 73k5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kwcdawgfan, Feb 24, 2001.
  1. kwcdawgfan
    kwcdawgfan Registered Member
    Jan 13, 2001
    91
    Georgia
    What type of gasket goes on the tailgate on each side of the window... When mine is closed and rolled up Ive got a hole on each side that I can put 2-3 fingers through... There are several holes drilled into the tailgate at these spots like some kind of plate or gasket may have been screwed to it at one time... Thanks for any help....
  2. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    There is a plate that resembles the plate that is on the both doors. There is also a piece of rubber that is attached to the hard top seal. It is probably missing just like mine! The top seal is 89.95 for the pair, and the plates are 12.00 each through Cheyenne Pickup Parts. <A target="_blank" HREF=http://www.cheyennepickup.com>http://www.cheyennepickup.com</A>
    Hope this helps
    Bigmeats
    Carl.....75 Blazer......Manhattan Il
