question re: priming fuel system.
Discussion in '1982-Present GM Diesel' started by colbystephens, Feb 17, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    when priming the system, everything i've read says disconnect the injector lines and remove the glow plugs and disconnect the pink wire from the IP. why do we disconnect the pink wire - what does that do?
  2. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    The pink wire is power for the IP. When I primed mine I just cracked open 2 injectors and turned it over in short bursts, about 5-6 seconds each. It took me about 8 cycles to get it flowing. Started right up.
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah, i'm familiar w/ the function of the pink wire, just want to know why everyone says to disconnect it while priming the system.
  4. bear76
    Oct 16, 2005
    1,065
    here
    I would guess you wouldn't want the IP pumping dry. So let the mech. pump push fuel into it for lube I guess.
  5. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    DING DING DING
    Johnny Tell Him What He's Won!:bow::bow::bow:
  6. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    You only disconnect the pink wire to get fuel to the injector pump. Should only take 2-3 10 seconds of cranking. Like mentioned above it is to prevent the pump from running dry.
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i gotcha. thanks.
