question regarding rear disk brakes and hard lines
Discussion in 'The Garage' started by ducttape114, Aug 22, 2003.
  1. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    caddi calipers on 14ff. i have heard that....
    your supposed to use a flexy line between the caliper and the hard line(the one that runs along the top of the axle tube). this is so that as the caliper moves frome brake pad wear the hard line is not stretched.
    when i was looking at my calipers, it looks like they are mounted to the braket such that they wont move at all. so did i hear wrong? whats the story? id prefer to not use any rubber if posible. thanks in advance.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The calipers have to move, or they won't work. /forums/images/graemlins/wink.gif The caliper slides back and forth on the mounting bolts as the brakes are applied. It also moves as the pads wear. You'll also find working on it a real pain in the a$$ without a flex line there. How will you move the caliper out of your way if it's hard plumbed? /forums/images/graemlins/eek.gif
    I've got some short flex lines attached to mine. They're Wagner Part # F-97661. To make the transition from hard line to flex line, I used front brake hard-line-to-hose brackets from a ’91 Chevy Beretta . I just cut them down and welded them to the axle tube. The flex line attaches to the bracket using a clip like the one that holds the front brake flex lines to the frame. Then the hard line just screws into the flex line. /forums/images/graemlins/thumb.gif
  3. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I used rubber lines for a 76 Chevette. They're nice and short and all the connections fit. Be sure to get the banjo bolts for the Caddy calipers, they are bigger than the ones on a Chevy truck.
  4. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    awsome, thanks guys
  5. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    If your worried about the rubber you can have some steel braided lines made to fit. /forums/images/graemlins/thumb.gif
