Question regarding Windstar fans
Discussion in 'The Garage' started by ryanstrucking, Mar 19, 2006.
  1. ryanstrucking
    ryanstrucking 1/2 ton status GMOTM Winner
    Feb 2, 2003
    182
    Calgary AB Canada
    Hey Guys.
    Yet another question for you.
    I'm going to be hooking up my windstar fans very shortly and was looking at the diagram someone had posted earlyer in regards to these and my concern is the relays. are 30 amp relays big enough? does anyone know what these pull for amps at start-up and once they are running?
    Heres a diagram of the set-up I'm refering to.
    Thanks in advance
    Ryan
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You'll want to use at least 40 amp relays with the Windstar fans. Those things draw some serious juice at startup!
  3. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
    I apreciate your reply but can you narrow down the serious juice a little more for me;). Just wondering if I should use a solinoid rather than a relay.
  4. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I used two 30 amp relays wired in parallel for each fan :D . Ghetto but it was cheap and I used the waterproof relays from a mid 90s cadi.
  5. dyeager535
    26,980
    A good idea would be to go get a Ford Windstar wiring manual (autozone has them online?) and see how they wired them. However they did it is likely going to be a bit overkill, but safe.
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    On my 71 ElCamino I ran a pair of 30A like you have shown and had no problems.
  7. afroman006
    Aug 21, 2002
    2,876
    I have a single relay for each fan on my burban but one day they just wouldnt come on so I wired the fans straight to the battery for the trip to my shop where I tore the burban up. I never tested the relays once I got them out but I'm almost positive they were dead.
  8. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    :D dont mean to hijack but what year windstar fans did/do you use?:confused:
    thanks Shawn:D
  9. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Those Ford fans draw up to 90 amps on startup. You'll definitely kill a 30 amp relay pretty quickly. Might be worth it to go with a couple of Ford remote starter solenoids or something instead :)
  10. dyeager535
    26,980
    Can't find the wiring at autozone (not up yet apparently) but from what I could find, Ford used two different relays, because of the high speed and low speed fans.
    Would obviously make sense to use the same one for both, whichever was the highest rated.
  11. ryanstrucking
    Feb 2, 2003
    182
    Calgary AB Canada
  12. 88Silverado
    Mar 13, 2003
    2,664
    OOps, I errored. I used 50A Bosch relays (0-332-209-138, one for each fan) and they worked fine. Relays are rated at max full load. They can take a higher load (within reason) for short durations.
