Question reguarding 94 Wrangler
Discussion in 'The Garage' started by jeepinzone, Feb 21, 2003.
  1. jeepinzone
    jeepinzone Newbie
    Jun 16, 2001
    4
    Rochester, NY
    I have a question reguarding my 94 Wrangler...Whenever i drive it it seems to make a grinding noise at 35mph or lower...it just comes and goes whenever it pleases, it has just started doing this and i dunno what the problem is? Maybe there isn't enough oil in the transfer case? i dunno, any help would be well appreciated! Thanks.
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Could be low on fluid. Or a u joint.
    John
  3. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    you might want to pull your diff cover and check things out. my wife's 93 was doing something similar and i tracked it down to diff area. i pulled the cover and it had 3 busted teeth from the pinion.
