Question: What Size Pipe Do I Use For Dual Exhaust?
Discussion in 'The Garage' started by Looksback, Feb 10, 2003.
  1. Looksback
    Looksback 1/2 ton status
    Aug 12, 2002
    120
    Montana
    I have a '86 K5, with a 305ci motor, and I am thinking of dual exhaust, but I do not know what size pipe to use, I know there has to be some back compression so I do not want to use to large of pipe. Any suggestions on what size pipe to use?
    Thanks for the help
    LooksBack
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    2 1/4" is your best bet. It will also work well with a 350 if you decide to upgrade when the ol' 305 kicks the bucket.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    2 1/4" is what I went with. It works well on my 350.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    what they said
  5. Storm Trooper
    Nov 24, 2000
    4,640
    I used 2-1/2" Aluminized pipe and dual inlet/outlet Stainless Flowmaster muffler on mine but I have the 350HO.
    If you want to keep it for a long time and might upgrade the motor (like it or not) I would use 2-1/2". 2-1/4" will also work fine with your motor. Motors do like to breath and a good muffler will create all the back pressure you need.
  6. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    My mechanic recommended 2.5" with cats only (no mufflers) but we were planning on swapping in a SB400 so at the last minute we decided to go with 3". It came out way too loud. It's kinda cool, but I've got to get some mufflers on there now to make some back pressure (and stop annoying the neighbors). 2"-2.5" is probably a good range depending on your intake, carb, cam, etc.
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">Back when I had dual exhaust I ran 2 1/2".
  8. Looksback
    Aug 12, 2002
    120
    Montana
    Thanks for the help, that is what I had though might work so I think I will use the 2-1/4" pipe. as for the motor it is in perfect running condition so I will be a long time before a new one is needed. If I were to gett a motor my choice would be the 366ci big block, but I dont know if I would ever gett it to fit under the hood.
  9. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have duel 2.5in on my 350 /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    I run 2 1/2 myself. You might be able to get away with 2 1/4 with the 305.
  11. 91k5NC
    91k5NC 1/2 ton status
    Jul 12, 2002
    206
    Durham Nc
    i went with 2 and a half and seems to be fine with a 350.
  12. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I've got 2.5" from the headers to the 40 series Flowmasters, then 3" from the mufflers up over the axle and out the back. It is lets the healthy 388 breathe pretty well. It is a little noisy, but sounds good when I press the go pedal /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  13. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I have a true dual 2-1/4" system behind my 350...I will be using either true dual 2-1/2" or 3" behind my BBC, but I am ditching the cats too...
    Chris
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    2.25 for duels will give you the propper back pressure.
  15. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    what would u guys use for a 454?? im thinkin 3" true duals all the way out and behind the tires. right now i have 2 1/2" for my 350, but it crapped so in comes the 454....
    NITRO
  16. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    2-1/2" duals are good for your 454. Dual 3" is not really necessary until you are near 450hp.
