QUESTION
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Apr 23, 2000.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I have an 87 K5 with 350 tbi, 700r4, 3.08 and 33" tires. I want to put a 12bolt rear with 3.42 gears that I got from a 79 parts truck. front gears also. Will my performance increase or will it stay the same? I also have a th350 mated to a 203 x-fer case. could the x-fer case be mated to the 700r4 without troubles? Thank you for your help.
  2. mudfanatic
    mudfanatic 1/2 ton status
    Feb 18, 2000
    614
    Aloha, Oregon
    I'm not sure about mating the 700 to the 203, if it can be done I am sure that advance adaptors can tell you, and if they havent tried it yet they might be willing to try it for a price.
    '77 K5
    PS. changing gears you will definetely get better low end power and changing from a 10 bolt to a 12 bolt you will gain strength.
    <font color=red>mudfanatic</font color=red>[​IMG]
  3. walrus101
    walrus101 Registered Member
    Apr 9, 2000
    91
    texas
    mudfan said it all. advance adapters will be able to answer the quetions, and anytime you change gears to a lower ratio (numerically higher) you will get better performance. my ford 9 had stock 3.08's and i put 3.55 in, and my mustang gt not only had improved acceleration, but i got better gas mileage.
    walrus101
    goo goo gaju
