Question?
Discussion in 'The Garage' started by Prime, Sep 3, 2005.
  1. Prime
    Prime Registered Member
    Aug 22, 2005
    10
    British Columbia
    does anyone know about adjusting the bands on a 700r4?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    you dont
    ryan
  3. Prime
    Aug 22, 2005
    10
    British Columbia
    Niether do you.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    ok...so you want to adjust the band. well for starters you need the j33037 which is the 2-4 intermediate band apply gage. then you need to disassemble the 2-4 servo housing. then you can install the j33037 and and the band apply pin. then you secure the j33037 to the case with the snap ring from the 2-4 servo cover. apply 98 lb in torque to the j33037. if the line in the j33037 is visible the pin length is correct. there are three 2-4 servo pins:
    2.59-2.60 inches with one groove
    2.65-2.66 inches with two grooves
    2.70-2.71 inches with no grooves
    does that answer your question?
    ryan
