Question?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by conv76jimmy, Aug 22, 2001.
  1. conv76jimmy
    conv76jimmy 1/2 ton status
    Feb 18, 2000
    281
    Yay Area, CA
    Does anyone know how I can find out if my 1976 Jimmy came stock with Single Pipe Exhaust or a True Dual Exhaust System.
    2-wheel'n all the way!!!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I believe that they all rolled off the line with a single exhaust system - I've never seen an original with true duals.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. conv76jimmy
    Feb 18, 2000
    281
    Yay Area, CA
    Does that include 2wd Blazers &amp; Jimmy's. Reason i'm asking is
    because a saw a 2wd Blazer that had been converted from a 4wd to a 2wd Blazer and it had true dual exhaust and in california i don't think you change the exhaust and be able to pass smog.
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    In CA you can make it dual exhaust as long as you run dual cats. also....Dan
    If it ain't broke.......Don't fix it....
