Questions about 14 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazingboy, Feb 22, 2002.
  1. blazingboy
    blazingboy 1/2 ton status
    Dec 2, 2001
    120
    Georgia
    Ok guys I am thinking about buying me a 14 bolt but I want to know what kind of mods I would have to do and could I convert it to a six lug and could I use a 15 inch wheel
  2. 84Sierra
    84Sierra Registered Member
    Jun 1, 2001
    43
    Cleveland
    You can convert the Semi floater to 6 lugs but not the Full floater.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The Full Floating 14 bolt CAN be converted to 6 lug, but it takes custom machining to do. If you do a search you can find info on the 14bff converted to 6 lug. Or like said earlier, you can convert the 14bsf to 6 lug. There are also 6 lug 14bsf available, they are under post 87 Chevy light duty 3/4 ton pickups. They will need to have the spring perches, and shock mounts moved to work in an older K5. There are probably also some other stuff needed too. Just not sure what they are.
    My Chevy isn't broken, its just out of gas.
