Questions about 32spline 205 from a manual tranny
Discussion in 'The Garage' started by arq, May 23, 2003.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i can get a np205 from a manual tranny setup. could I use this for a doubler??? I know the input shaft is longer, i could just machine that but how bout the bolt pattern??
    ARQ.
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    A late 32 spline 205 should be just fine as a doubler. AFAIK, the input on the late 465 205s is the same as a TH400 205. You just need to tell Stephen you have a round pattern adapter/retainer...
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I think the round-pattern Doubler requires swapping in the short 32-spline input... maybe Stephen will chime in to tell us for certain. /forums/images/graemlins/wink.gif
    The spline only reaches in so far. If you machined it down to length of the short input, I think you'd lose most - if not all - of the spline engagement
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    So the late 32 spline 205 has a longer input? I thought I had read it was the same. In any case, asking Stephen is definitely the way to go...
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    arq,
    no you cant machine it down. i have one sitting here.
    you have one of two options. do what russ and i are doing, 31 spline from a ford. goes right in. well, in my case and your case. russ had a small problem. his chevy case didnt have the aluminum seal housing. he made a spacer or something. i dunno, cant remember right now to much in head...
    or option two, buy a short 32 spline input. ORD has them.
    option one would only work for the doubler. option 2 will work for anything. that is anything that needed the short input.
    you cant machine down the long input as for the splines only go back about 1.25 inches or so.
    Grant
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    Russ,
    the late models have the long input. this is why i have to do the same thing you had to do. mine is the long input.
    Grant
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ahh, I remember that now. I think I was suffering from heat stroke earlier. Wires crossed in the brain... So much stuff to keep straight in such a small container...
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    I think i'll pass on the deal unless anyone is interested.
    ARQ.
