questions about 700r4 TV operation
Discussion in 'The Garage' started by R72K5, Aug 9, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i need someone to try and explain to me- in layman's terms- how the TV in the 700r4 trannies works,
    does the tranny hold gears and shift firmer the farther the cable is pulled, or ??
    if so then how do you explain that the tranny will hold a gear for a very long time and will make the shift very hard when the cable is disconnected
    i dont understand it
    also can you replace a 700r4 cable with trans in vehicle and without removing the pan? has anyone done this ? is it possible to do ?
    i need tips/info
    thanks
  2. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Have you seen this yet ??? Might help, answered all my qusetions about it.
    Click here.TV 101
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    thanks i will check it out :D
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    can someone please explain to me on an 88 700r4 trans how in the heck to keep the cable and the TV rod link together when replacing the cable ??
    what is the trick ? it is impossible! it just falls apart as soon as you let go ?
    do i need to weld the damn cable to the link or what ??
    thanks
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    got it.... finally,, had to have someone pull the cable taught while i was underneath keeping cable end on the damn Tv link rod.,.,
    that was fun....
    the new one is identical ot the original one
    so i dunno ??
    the sheath is completely back all the way, and the throttle will go WOT
    whats wrong here ?
    hum,...
    thanks
  6. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Have a look at the tv101 article (tab at the top of the page). It is really useful and easy to understand. Never fitted a cable on mine so can't say!
    www.tvmadeez.com
