questions about a np 203
Discussion in 'The Garage' started by jmann, Mar 18, 2005.
  1. jmann
    jmann Registered Member
    Mar 18, 2005
    10
    Yakima, Wa
    I am new to this site and I have a question about my np 203 t-case.
    1. How do I tell if it is full time or a part time.
    2. When i am driving down the road and I put my hand on the shifter and I let up on the gas I can feel a clunk in the shifter. Can somebody tell me what the clunk noise is. first I thought it was the u joints but I changed them and it is still there.
  2. chasone64
    chasone64 Registered Member
    Dec 15, 2004
    88
    Oregon
    1. All 203's are full time, unless someone installed a part-time kit in it.
    Do you have locking hubs? If not it should be full time. Only way I know to tell for sure is raise the front wheels off the ground & try to turn the drive shaft, while in hi & hi lock. If the shaft turns while in hi & not in hi lock it is part time.
    2. I would check the chain in the 203 case. I bet it's stretched & is slopping on the gears between accell & decell. (Happened to me on my last one)
    If so have it replaced.
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    2. When i am driving down the road and I put my hand on the shifter and I let up on the gas I can feel a clunk in the shifter. Can somebody tell me what the clunk noise is. first I thought it was the u joints but I changed them and it is still there.[/QUOTE]
    check the x member bushings and u joints too:thumb:
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Its probably the chain/ When they wear they will make a clunking sound. My old K20 does it whenever I'n not easy with the gas.
