Questions about D60 crossover, e-brake cables, 14bff-sf spring plate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88K5Jimmy, Dec 19, 2002.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Here they are:
    Anybody used ORD D60 crossover with the axle moved forward 1"? If so, have you had any contact with the drag link hitting the passanger front spring?
    After lifting the rear of the truck the driver-side e-brake cable appears to be too short. Is there any way to lengthen it? If not, where to get a longer one?
    What spring plate can I use after doing the u-bolt switch on a 14bff? Can I use the spring plates off of a 3/4 ton 14bff/14bsf? <font color="red">DONE</font color>
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    You can use same spring plates between between sf and ff axle. /forums/images/graemlins/burb.gif
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
