questions about diffs
Discussion in 'The Garage' started by THE REV, Jan 23, 2007.
  1. THE REV
    THE REV Newbie
    Jan 23, 2007
    Siletz Oregon
    Hello out there and hope that everyone got what they wanted 4 chriistmas.My question is I,ve got a 12 bolt reardiff and a 10 bolt front diff,I,ve always thought that a 12 bolt was a posi am I wrong?.Oh this is a 76 c10 4x4 auto trans.Also I was told that the front diff is a different ratio dont know why but is,nt this a bad thing???. Just wanted to know thanks 4 all your help.Oh by the way do,s anyone have a wiring diagram for the dash lights of same truck??.thanks again will be waiting for some help.
    THE REV:weld: :grind: :hack:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    If it has any kind of traction device in the rear, it is a gov-lok. The factory never offered different ratios front to rear and if your truck actually has that, then yes, that is bad.
  3. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    c10? K10 :)
  4. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    The axle itself doesn't have anything to do with weather its locked or not. You have to look inside. Axles that have different ratios front and rear cannot be driven in 4wd. Different gearing is probably the result of swapping in an axle because one broke before.
  6. 1977k5
    May 26, 2003
    9,996
    134
    It can if he has a full time 4WD t-case with a center differential (NP203 :deal:). That will burn up the differential in the t-case pretty quickly though.
  7. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    yeah, having different ratios front to rear would be a big problem on any surface with decent traction. you could get away with it in soupy mud, probably, but i don't see it helping. it would be funny to see, if the truck was a cartoon. faster front wheels would make the front run away and stretch the thing, and faster rear wheels would advance to fast and turn the truck into an upside down taco. that, i'd like to see :haha:.
