Questions about DRAC's *Update*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jc71355, Feb 23, 2003.
  1. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    Questions about DRAC\'s *Update*
    I've tracked my speedometer problem to be the DRAC module in my 91. I was reading in my manual and it says that you can get different DRAC's when you change tires. Has anyone had success with this? Also how much can I expect to pay for it, I just found out that it's a dealer Item only /forums/images/graemlins/crazy.gif
  2. dyeager535
    26,975
    Re: Questions about DRAC\'s
    Sounds to me like you'll have to call the dealer, or write the folks over at www.gmpartsdirect.com an email to see what they have to say price-wise.
    I thought the DRAC on the trucks used a dip switch array that was used to "calibrate" to tire size?
  3. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    I called the local Dealer yesterday and they guy was having a hard time looking it up. We kinda got in an argument 'cause he said it was aftermarket and I said I'm looking at it right here in the service manual. So I got the part # off the box and called again today and he said that it is discontinued /forums/images/graemlins/angryfire.gif Has anyone else ran into this problem?
  4. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Several times.It's irritating to finally get part # for them to only tell you they have been discontinued.A good parts person can find NOS parts if they will take the time,but,it seems like when they're not considered warranty parts the dealers don't want to mess with them anymore. /forums/images/graemlins/thumb.gif
  5. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Re: Questions about DRAC\'s *Update*
    think the 'kit' was about $40 or so @ dealer on mine. got a pigtail, instructions and a couple of the clip-off pins. Haven't done the dirty work yet of taking it apart to install.. (something about a temp of 0 latley!)...
  6. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    You have a Part # for that? /forums/images/graemlins/grin.gif
  7. woody9
    May 27, 2001
    602
    Howell, MI
    um, have it yes. have it where i can put my hands on easy.. no. (work schedule has me smothered until the weekend, but would be happy to hunt it down then?)
    Seems there was a post or web-link on it @ a suspension site for some reason, but don't recall where i had found it. If i stumble across that I'll post it as well.
  8. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    That's fine I'm the same way. /forums/images/graemlins/thumb.gif
  9. woody9
    May 27, 2001
    602
    Howell, MI
    FOUND IT! /forums/images/graemlins/smile.gif 25085515, Reprogram kit. Hope this helps! /forums/images/graemlins/burb.gif
  10. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    One more question if you don't mind, Does it have the whole box or do you modify your exhisting one?
    Thanks, James
  11. woody9
    May 27, 2001
    602
    Howell, MI
    the part in this kit just plugs in and makes the adjustments. I haven't installed it yet (just do the calculations for how far speedo is off). /forums/images/graemlins/shocked.gif
  12. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Were is the DRAC located and what does it look like ?
    Dan...
  13. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    GM parts direct has it for $26.51. /forums/images/graemlins/grin.gif
  14. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    Yes, the DRAC is on the great gm disco list. www.instrumentsales.com...........you provide gear ratio...tire circumfrance...$75 and you are back in buisness.
    DW /forums/images/graemlins/usaflag.gif
