Questions About Factory Options
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Jun 19, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    On the sticker that's on the fender, it says that it is a Sequoia Special. What's a Sequoia Special? Also it says that I have a locking diff. What kind of "locker" do I have, I thinks its the Gov-Loc, right? Thanks for your advice.
    http://www.blazer.coloradok5.com is now under construction[​IMG]
    YEEEE HAWWWW[​IMG]
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Mine says I have a locker too, but I think its really a limited slip. They just called it that for some reason. I may be wrong...
    Brian
  3. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Yeah, I figured it was a posi rather than a real locker. By the way is there any kind of posi additive I should put in the oil?
    YEEEE HAWWWW[​IMG]
  4. Mikee
    Mikee 1/2 ton status
    Mar 9, 2000
    193
    Suffield, CT, USA
    No clue about the sequoia package, but the locker is most likely a eaton limited slip made for GM, unless it is a military truck which is then a Lockight LOCKER.
    "Got stuck once, hung up on top of a Jeep!"
  5. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Only time I've heard of a "Sequoia Edition" was a special edition of the Toyota ForeRunner. Don't know if it's just a sticker someone else thought was cool?
    Brian
    89KBlazer
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    This is a new one on me, can you offer some prove, on the Lockight LOCKER..............
    Thanks alot
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    The posi uses the same fluid as a diff w/o the posi. I think its 80w-90
  8. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
  9. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    gm has an additive that must be used when fluid is changed. regular gear oil is ok, but the additve MUST be used.
    your right. I don't understand the jeep thing!
  10. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The factory option limited slip diff was called the "Gov-Lok" by GM, or listed as a locking differential on the option sheet. I really wouldn't consider it a true locker as it definitely not in the same class as the Detroit Locker or Lock-Rite. The Gov-Lok has a reputation for failing and being rather ineffective, though some people have had good luck with them.
    The factory owner's manual states that a limited slip additive should be added to the standard 80w-90 gear oil. The additive contains a friction modifier that is supposed to make the clutches operate smoother and more effectively.
    Concerning the Lock-Rite, I have never heard of them being used in military trucks. The mid-80's GM military pickups had a Detroit Locker installed in the rear 14-bolt axle, and I believe the military Blazers (CUCV's) used the standard Gov-Lok in the rear 12-bolt axle.
  11. Executioner
    Feb 22, 2000
    1,530
    Your factory owner's manual is wrong, or my 77,78,and 79 factory owner's manual is wrong !
    I think i have read on the Eaton web site that one of the main reasons GM asked them to design the Gov-lock
    was to eliminate the need for friction modifier . My three list 80w-90, that meet a GM spec. no mention of
    any additive.
    care to explain ?
