Questions about going doubler
Discussion in 'The Garage' started by b454rat, Mar 11, 2007.
  1. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I'm thinking about getting a doubler for my 89, the 92 Blazer from Eastcoast isn't panning out, which already had the doubler in it. I can get a 203, pretty sure an adaptor, but the trans I have is 2wd. I had 2" spacer made (MEK5) so I could use a 208/241 adaptor with a Ford 205. Looks like the factory 400/203 used a really short output, but where would the spacer have to go?? Or do I even need a doubler?? But it would be cool....
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    which tranny do u have now?? if u are running a ford 205 they are 31 spline, so how did u address that?
  3. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I have 2wd TH400, Ford 205 that I swapped the inputs with a GM 205. The GM205 was out of an 86, can never remember if that is long or short output. I'm toying with the idea, I don't really need a doubler, but figure if I still have the money, better get it now.
  4. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    the output in your tranny will most likely be way too long for the 203. u would need to acquire the proper tailshaft & have it swapped in. if your 205 is the long front input i think u may have to swap it to short if u are going w/ the ORD doubler.
    on another note i would not waste my money on a doubler if i knew i didn't need it. by time u buy the doubler, doubler shifters, acquire the right cases, buy new d-shafts, & fab crossmembers. u could spend a couple thousand on the conversion.
  5. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I could get the right output or even the whole tranny. The only thing that I would really have to buy is the doubler kit itself. Dunno what I want to do, looking for ideas or opinions I guess. Probly just run what I got, put the money elsewhere, inless I can get a deal on a setup.
