Questions about mounting a CB on the roof......
Discussion in 'Communication (CB | GPS | HAM)' started by BlazerGuy, May 7, 2001.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What kind of screws should I use to attach this sucker to the roof? And what guage wire should I use to wire it to the battery? Thanks
    Murphy's Laws on Life :
    "It is a mistake to allow any mechanical object to realize you are in a hurry."
  2. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Decide on your antenna then get an appropriate roof mount. IE: Firstick FL and roof mount.
  3. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    careful, roof mount stick up higher, and can be a bitch on the trail.
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  4. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    are you talking about the antenna on your roof or mounting the radio itself to the roof on the inside of the cab?
    peace.
    HAYDUKE
    Insured By COLT, Policy #.357M
    <A target="_blank" HREF=http://haydukesk5.coloradok5.com>http://haydukesk5.coloradok5.com</A>
  5. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    I did both and it worked out sweet, not for the faint of heart though. I have a light weight wilson and it bends no matter what I hit. If you want more info just reply back to this post. I'll give you the full low down.
  6. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I was talking about mounting the radio to the roof, I think I'm going with a mirror mount antenna
    "The longer you wait in line, the greater the liklihood that you are standing in the wrong line." [​IMG]
  7. taterblazer
    Feb 2, 2001
    277
    Boise, ID
    I did a roof mount and it was moderately hard. Have an early post on how to do it. Just use short screw so they don't impact your roof. It's to layers. Use lock washers. Then line up the head board as best as possible. I then smacked it into the bracket to mark it. Cut some slits in it and slid it over the brackets. Looks good but you have to slice the liner.
  8. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    I mounted my CB on a good slide rack, between the sun visors. Worked out great for years. Till I rolled my truck at 50mph and it almost "ripped" my nose off my head! GOPHERKILLER
