questions about my current exhaust situation...
Discussion in 'The Garage' started by muddysub, Oct 6, 2002.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    well as i stated in another post, my muffler fell off last night. so right now the exhaust ends at the middle seat. (suburban) and i noticed i get some fumes in the truck when it sits in one spot too long. can i buy a straight 5'-6' length of exhaust tubing? will the fact that my exhaust system is about 6' long and all it has in it is a cat hurt the motor? do i have enough back pressure with the way it is right now? can anything be damaged by my current exhaust "setup"? /forums/images/graemlins/confused.gif
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    dont worry, just see if you can run it out to the side, like before the rear tire, thats waht i did to mine, sounded good too /forums/images/graemlins/smile.gif, i did mine with 2 1\2 inch SS flex pipe, worked well i dumped it right before the rear wheel so as your going down the road the whirling action of the tire creates like a tornato and churns the gases away from the truck, this is waht i heard from anotehr member when i was asking opinoins about an exaust solution, good luck, happy exaust making /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If I ever get my bills paid off and can start spending money on the Blazer again, I'm going to get some headers, and run dual 2.5 exhaust with Flowmaster 40 series mufflers. Probley dump it out infront of the rear tires with some Meg's exhaust tips.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    with just the cat on it you wont have enough back preasure
  5. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    So why have I seen trucks runnin Straight headers in mudboggs? It didn't hurt their engines.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes for a short amount of time it is ok and will give you more power but if you leave it that way it will burn up your valves /forums/images/graemlins/shocked.gif
  7. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Short bursts and higher compression will do OK with open headers, but stock compression and long drives will burn valves with too little backpressure, not to mention it kills low end torque.
  8. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Sorry to cut in on the post, but while you're on the subject I thought I would ask. You're talking about having enough backpressure. My truck has true duals run out to the corners. It's factory manifolds dumping into 2.5" pipe. That runs back to 2 hollowed out tractor glasspacks (the kind with metal baffles instead of fiberglass). It then runs out to 4" tips. Does this have enough backpressure? Also, when accelerating, the popping sound switches from the driver's side, to the passenger's. What do you think would cause this.
  9. muddysub
    Jun 23, 2001
    10,452
    489
    not sure about the glass pak duals question. but i was thinking about my exhaust today. would 3" pipe back to the rear axle and a 3.5-4" tip give me enough back pressure to be ok?.
  10. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if they are hollowed out then you are basically running straight pipes so no you would not have the corect back preasure
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    with or without mufflers and single or duals?
  12. muddysub
    Jun 23, 2001
    10,452
    489
    without mufflers and single.
  13. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    so that's what's making the pop switch from side to side? what do I do, but cat's back on?
  14. muddysub
    Jun 23, 2001
    10,452
    489
    an x-pipe would cure that. it equalizes the pressure from side to side.
  15. MudbogAD
    Jun 29, 2001
    672
    Oh, OK. Scott, just buy a new flowmaster or something.
  16. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you reallydo need to have mufflers on it /forums/images/graemlins/smile.gif just buy some 40 serise(sp?) flowmasters they sound awesome /forums/images/graemlins/smile.gif i like my exhaust to be 2.25 or 2.5 the 3in gives you more horse power but les tourqe and the 2.5 gives more tourqe but les horse power
  17. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    put a set of 40 serise flowmasters on /forums/images/graemlins/smile.gif
  18. muddysub
    Jun 23, 2001
    10,452
    489
    well the way it looks i'll be trying on my doug thorleys this weekend and buying a whole new system soon. i'm thinking single 3" with a hi-flow cat and a 40 series.
  19. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i ran 3 inch on my blazer, true duals, generic 18 inch double chamber mufflers, out the back at the corners. all on a stock motor.
    ran fine. high end was nice and sounded like a harley...
    grant
  20. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    [/ QUOTE ] nothing wrong with 3inch pipe you will get a good top end but a lesser bottom end
