Questions About Rear End
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ks-k5, Apr 2, 2002.
  1. ks-k5
    ks-k5 Registered Member
    Oct 2, 2001
    18
    Just South of Wichita Kansas USA
    I have a K5 with an auto tranny.... question is when I crowd it at low rpm I get a shudder/shake that seems to be coming from the rear end, does this sound like a rear end problem?
    How do I tell what rear end I have? and/or gear ratio?
    If thats what it is, what is the best way to go about correcting the problem, repair/replacement???
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    probly your u - joints need replaced . your axle is probly a 12 bolt ,count the cover bolts if there are 12 then its a 12 bolt and oif there are 10 im sure u see the logic..
  3. ks-k5
    Oct 2, 2001
    18
    I don't think its the u-joints, they look really good. This problem is only when I accellerate and then only at lower rpms.
  4. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    I i dont care how they look ,didya check em?
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You have a 12 bolt...the shutter could be alot of things...
    I would check:
    -u-joints
    -slip yoke
    -suspension bushings
    -leaf springs
    -shocks
