Questions about regearing and 1/2 to 3/4 ton
Discussion in 'The Garage' started by MOBK5, Mar 10, 2006.
  1. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    Im picking up a 14bff tomorrow and I dont know the gearing as of yet. Its out of a 70's model lwb and Im just guessing 4:10 gears. Im not going to be able to pick up a matching front due to it being 2wd, but my 10bolt is fine for now.
    All I need to know is the carrier break for 10 bolts, and when i get my 8 lug conversion for my 10bolt if I need the 3/4 ton calipers to go with the 8 lug disks. Ive heard the spindles are the same, and all I need is the disks and hubs. Please help me out guys.
    Thanks, John Miller
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    I don't now the 10 bolt carrier breaks but if I remember correctly there is a total of 4. you're right - the 10 bolt spindles are all the same, you'll just need the bearing hubs, rotors and caliper brackets. Your original calipers should work.
    Edit: Walter (Slamchops) just got a D60 so he should have a 3/4 ton front end he'll be getting rid of.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its either gonna be series III or series IV
    the break between III and IV is 3.40 or 3.42
    series II would be 2.56, 2.41, 2.28 etc, but those were mainly only in the cars, cept for a few trucks that had 2.56, but rare, ive only come across one ever so far, was a 2wd bonanza big 10, '77-80 year one, was 2.56 ratio listed on the RPO sticker
    but that ratio wasnt a 4x4 ratio, afaik
    randysringandpinion.com used to list the carrier breaks for alot of axle models,
    or at least i know they used to,
    before the revamped the site a year or two ago or so,
    its been a while for me
    good luck
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the carrier break for the 10 bolt is 2.56 and down and 2.73 and up. preaty much, you shouldn't need to change carriers.
    1/2 and 3/4 calipers are the same if the 3/4 ton had 11" brakes, the 3/4 ton have a larger piston with the 13" rear brakes. they will swap no problem.
