questions about stock front shackle angle
Discussion in 'OffRoad Design' started by redwood, Apr 19, 2005.
  1. redwood
    redwood Registered Member
    Mar 6, 2005
    9
    ak
    Why is it that the stock shackle angle sucks (near vertical on both my rigs before and after lift) and why doesnt anybody design any after market springs a little longer to be able to run a little longer shackle with a better angle? Does anybody have any pics/writeups on an easy/strong fix for this?
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    You can do your own 52" spring swap for a 4" lift plus whatever extra you give it with your own shackle. You can create your own shackle angle depending on how far forward you move the front hanger.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Honestly, there's nothing wrong with the shackle standing straight up and down, especially with the stock springs. In fact, with any flat spring, you NEED the shackle to be pretty vertical or you can end up with a stiffer ride.
    Also, on the GM's you have to be somewhat careful where you put the end of the spring so you don't hit the frame, so typically running a shackle at a kicked back angle involves a longer shackle.
    When you step into the specialty aftermarket world, kicking the rear of the spring back can help out in some cases. One thing we typically do with a custom spring is stretch them an inch or two to help kick the shackle back.
    As for the regular aftermarket world, keep in mind that most of these suspensions were designed in the 70's and 80's and they're not going to go back and re-do things when they're busy building IFS truck lifts now, so we're kind of stuck there. And most aftermarket companies built their springs around the existing shackle which limits what you can do with the spring.
    This is where smaller companies like us that specialize in these trucks step in with custom springs, and where you can do some custom work yourself to build it just like you want it.
    [start soapbox speech]
    Something else to keep in mind: bolting a regular aftermarket spring into the truck like a Tuff Country EZride still works pretty good and is relatively inexpensive which leaves you time and money to work on other important offroad mods like the drivetrain, body armor, recovery gear, etc. Avoid spending too much in one place like the suspension to the detriment of other important stuff. A better shackle angle on the front will not winch you out of a stuck.
    When you have the rest of the goodies to the point your happy, that's the time to start optimizing each system more thoroughly.
    [soapbox off]
