Questions about Trenches...
Discussion in 'The Lounge' started by mikey_d05, Jun 4, 2006.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Alright, I finally landed a new summer job at a private surveying/consulting/civil engineering firm. My time is going to be split pretty much 50/50 between the office and paperwork and field work, surveying, and staking. One of the things I was told that caught my attention is that I might be dealing with trenches once in a while.
    I know Paul has quite a bit of experience with this but he's on a cross country road trip at the moment. What are some things I should look for or guidelines I should use to know whether or not it's safe to go down into a trench?
  2. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Look for skeletal hands protruding from the soil at the bottom...
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    When the trenches reach a certain depth they are supposed to be "shored." Spoil piles are supposed to be spread out so all the weight is not on the wall of the trench. Softer soil has a greater chance of "sloughing off" into the trench and last but not least take a "Trench Rescue Class" it will give you all the information you need to stay alive. These classes are available as a first come first serve sign up not sure what they cost. Check into your local fire department.
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I know that in California there are apparently Open Trenches that you must watch for. I know this because we have signs that say "Open Trench", issued by the Department of Redundency Department. I therefore assume there are also "Closed Trenches" (which I also suppose everywhere else is called "The Ground"). You might want to study up a bit on the signs before jumping into either one.
    We also have Loose Gravel signs, but that is another training issue completely.
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I'll make sure I look for a sign that says "solid ground" before I get out of the truck. :p:
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Thanks for the link.
    So basically if it's up to my neck it needs to be shored. If it's not, I don't go down the ladder...correct?
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    RootBreaker has the item to take with ya..............................
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I haven't been around much...what'd I miss?
  10. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    There are different factors for different types of soil. and different slopes (degree of angles) for the trenches to be cut for these soils. Different conditions exist also such as rain the day of or the day before going down into the trench. How far away from the edge of the trench where the spoils have been set. Is there machinery vibrating the soil nearby. Many factors.
    Maximum allowable trench with out the engineered slopes is 4 feet without shoreing.
  11. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
