QUESTIONS ANSWERED, PLEASE DELETE THIS, THANKS ALL
Discussion in 'The Garage' started by 4xcrazy, Feb 10, 2004.
  1. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Any body know if 15" 8 lug rims will fit on the 14bff over the 13" brake drums? The 13" measurement is for the brake shoes though,the drum is bigger, just not sure how much.
    Thinkin about doing a comversion to rear disk, will the rims still clear without much modifying?
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/burb.gif
  2. chev4life
    chev4life 1/2 ton status
    Jun 21, 2001
    416
    San Jose, CA
    Re: 15\" 8lug rims on a 14bff?
    I am wondering the same thing...will they fit a disk conversion...and to add a little (trying not to steal) to your question...will 15's fit 3/4 ton front breaks? whats needed?
  3. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i do not have first hand experence but every post that i have read about this states that 15 inch wheels are no problem on 3/4 ton and 1 ton 14 bolt ff with drum brakes.
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yep, piece of cake. I had to clean up one caliper to fit the 15 X 10's on my 14BFF with rear disks. I would go disks if I were you....easy and well worth it. BTW, my rims have a back spacing of 4.25" /forums/images/graemlins/waytogo.gif
    Here is a pic:
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    As far as I know there is no clearance issues with disc or drum. /forums/images/graemlins/thumb.gif I run 15x10 with 4.25 backspace on my 14B with discs. There is more clearance on the rear than the front. This is for steel wheels though. Aluminum is a diff story......
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes 15" rims fit 14bff's no problem. the only thing you have to worry about is the front axles. calipers. the rear clears easy but you have to make the front fit with the grinder.
    Harley
  7. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    with disks you might have to do some caliper grinding depending on how much backspacing you have /forums/images/graemlins/waytogo.gif
    no problems with the drums...
  8. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Just a FYI 3/4 ton and 1/2 ton front ends are basically the same. The 3/4 ton just has 8 lugs. It's when you go to a 1 ton D60 that you have caliper clearence issues with 15" rims.
  9. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    The 3/4 ton front ends are basically the same but the caliper support/backing plate is a bit larger. Most people will have to grind a bit to make 15" wheels work on a 3/4 ton front end (depending on the wheel back spacing).
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Finally seeing the light Tj, from what I see on here the reason people run 15" rims is for the larger available tire selection /forums/images/graemlins/thumb.gif
  11. 4xcrazy
    Oct 31, 2003
    9,472
    5
    HEY PAUL,,, /forums/images/graemlins/whistling.gif
    BITE ME !! /forums/images/graemlins/yikes.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/yikes.gif
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Hey Tj .....when was the last time your truck DROVE /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Just kidding back bro. Yeah get over here and help me lift my truck Saturday. /forums/images/graemlins/thumb.gif
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    If you want to run 15's on 3/4 ton you WILL (most likely) need to grind. If you run 4 1/8" back space you will have to grind a fair amount on the backing plate AND also the caliper. Trust me I know.
    If you run less then 4 1/8" BS (numbers closer to zero) you have to do less grinding the less you run.
    Harley
  14. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That is incorrect. /forums/images/graemlins/deal.gif /forums/images/graemlins/dunno.gif
    The 3/4 ton rotor is larger in diameter. Because of this, the caliper is further away from the axle centerline. This is where the interference comes from.
    Like Harley said, the amount you have to grind depends on the amount of backspacing you are running. I had to modify the caliper support AND grind the caliper to fit wheels with 4.25" BS.
  15. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Seems to me since i have to buy wheels anyway, it would just be easier to go ahead and buy the 16"wheels then???
    maybe /forums/images/graemlins/pimp1.gifsome /forums/images/graemlins/pimp1.gif17" /forums/images/graemlins/pimp1.gifor even 18"s /forums/images/graemlins/pimp1.gif
    Less work and headache, and anyone who knows me,,,,PAUL knows i don't like alot of work. /forums/images/graemlins/grin.gif
    naw i'm just gonna stick with the 16's and just deal with those tires when that time comes.
    Thanks all for the responses and the advice/help.
  16. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Ahh then I was misinformed. I was told the 3/4 ton D44 and 1/2 ton D44 were identical save the 8 lug rotors.
    I would stick with 15" rims but if you do go bigger stay away from the 16.5" ones.
  17. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Yeah i was already informed about those 16.5's not going to play with those things.
  18. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Not trying to be too much of a prick......but if you do a search you can read threads on this for the next 2 weeks straight......
  19. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Already got all the asnwers i need for my decision, thanks for all the replies, and i'm too lazy to search.
  20. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    and i have seen 15 x10 wheels on a '67 GMC dana 60 FF rear axle too, very easy fit no problem at all
