Questions bout my 68
Discussion in 'The Garage' started by oatsk5, Jan 19, 2005.
  1. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    Just got it and have to relocate the rear spring pads on the axle just wondering the best way to go about doing it and can i up date the steering colum to a newer one any info would be great thanx
    ERV
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you could go with a 79 older van column, but some mods to do for firewall mounting and seal and such, oh and need turn signal switch wiring adapter from chevy parts counter, have fun
    72 up pickup one be wiring nightmare since ignition is in column in them
    rear spring perches removal requires removing the frame rivets that hold them to frame rail
    grind and punch them out
    its not that bad if you have grinder and patience and goggles and earplugs and soem grade 8 hardware
    whats wrong with the 68 column ??
    whats specs on the 68 ? 68 chevy trucks are my all time number oen favorite trucks in the entire world, my first chevy was a 68 truck years ago, miss it alot, had a bunch, all gone now and cant find one anywhere now
    good luck
  3. oatsk5
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    nothing wrong with the colum just wonder if it could be done no biggie i acctually ment the pads on the axle tubes its a lwb for now and its ffact 3/4 ton but theve been up graded to newer version with 4.56s it may or may not be stick or auto it will have a 350 hopefully tbi all in due time pics in my member section
