QUESTIONS FOR A FREE 14 BOLT TO ME HELP!!!!!
Discussion in 'The Garage' started by Curtis2kul, Oct 8, 2003.
  1. Curtis2kul
    Curtis2kul Registered Member
    Oct 15, 2002
    62
    Winston-Salem, North Carolina, United States
    my uncle has a 77' or somewhere around there chevy stepvan, it has a 14 bolt ff axle, ive heard that these axles, or rearends, are longer than regular 3/4 ton. If so would this match the same length as my front. ITS FREE, i dont care if the spring perches line up beacuse im going to move them anyway. SO WILL A STEPSIDE VAN 14BOLT BE JUST LIKE A 3/4 TON WITH SPACERS? /forums/images/graemlins/crazy.gif /forums/images/graemlins/ooo.gif /forums/images/graemlins/k5.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yes it would be like a 3/4 ton with spacers. And the placement of the spring perches would have to be moved for a stock K5 but the new spring perches fit aside the old ones so the olds don't have to be removed.
  3. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    Depends on the step van.
    Is it a g30 ?
    How big of a step van is it ?
    Best thing to do is measure it. /forums/images/graemlins/grin.gif
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    the van axles are the same width as the front axles on our trucks---soooo, the track width is the same front and rear, instead of the narrow rear axle
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    watch out- it may cost you more even though its free. . . in brakes and fixing blown up gears i've spent over $1200 on my 14FF that i bought for $200.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    oh- and those will be JB7 brakes. much confusion among which drums to order when i had mine repaired.
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    If it needs brakes just get disks... I did and love them and I dont think you will save much on $$$ goen with drums
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    well- i considered it, but i know there's a lot of work to it, and i think it woulda costed a lot more. . .ony mines in partricular anyway
  9. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    not really disk brakes on a 14 is a completely bolt on modification and it only cost me $250 for everything.
  10. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Did you need a proportioning valve? Or did you just get the bracket, disks and gm calipers?
  11. Curtis2kul
    Oct 15, 2002
    62
    but it is out of a working van, if i want it i can go get it, sounds better than paying 350 for one from some junkyard
  12. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Well I have a Van 14bff in my blazer from a 1980 G30 and other then it being 3" wider it is the same , (other then the longer axle shafts too that is) the perches do need to be moved and if they are the cast one's. GET A BIG GRINDER..Slap on some disk's and all is good..
    Here is the cast perches..
    And this is the end result with the van width axle front to back match..
  13. Curtis2kul
    Oct 15, 2002
    62
    nice work, do you have any pics on the spring perches you put on, what did you use for the spring perch?
    OH, YEA , THIS IS OFF A DUALLY VAN, WILL THAT AFFECT ANYTHING??????????????????
  14. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    dually van? No matter what it affects things. Its either plenty wider than your front axle or I don't know what the other option really is.
  15. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    well here is the one that came off..(my finger kidjethro's grinder)
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Sorry I can't find any of the one's that went on they were nothing special just run of the 4x4 store perches...lol
  16. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    dually has bigger brakes.
  17. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Here's a couple pics of the perches I welded for NoSmog..
    I removed both of the old cast perches in less than 10 minutes apiece. Mike can back me up on that- He watched me do it. /forums/images/graemlins/pimp1.gif
  18. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Oh yeah, and this is my 14b..
    [​IMG] [​IMG] [​IMG]
    I like mine shaved... /forums/images/graemlins/thumb.gif
  19. Emmettology 101
    May 9, 2000
    8,126
    FL
    Get some measurements and pics! My guess is that if it is a dually van either it is a regular dual 14FF or it is a reguler width 14ff with dually hubs. And the again it could be a van width with dually hubs.. Get some pics of the van and the housing plus measurements! /forums/images/graemlins/smile.gif
  20. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    the hubs are the same, its the brakes are bigger.
