Questions for you np205 experts
Discussion in 'The Garage' started by Scrubby, Feb 16, 2005.
  1. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    I have 2 np205 cases. One is out of an '80 one ton and in really good shape. The other is out of a '75 3/4 ton and is pretty much worn out. Of course, the '80 case has a slip yoke. And the front yoke is a plate looking setup instead of a yoke. I am assuming that I can take the fixed yoke rear and the front yoke off of the '75 case and they should bolt right up to the '80 case. Am I correct before I start tearing into things? Or should I just look at rebuilding the '75 with parts from the '80?
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    you can use the fixed rear yoke off of the '75 case, but you cant use the ujoint yoke for the front output. the '75 case has a 10 spline front output, the '80 has a 30 spline front output (for reference) and all NP205's have 32 spline rear outputs.
  3. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    everything should interchange as stated. All the shafts are interchangeable. There isnt a whole lot in a 205.
    When you are done building up a good case I need a shift rail ball and spring and the rod that goes between the shift rails if you are interested in beer money.
  4. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    cover shipping and we'll hook you up. PM me.
