Questions on CB
Discussion in 'Communication (CB | GPS | HAM)' started by protechk5, Mar 19, 2007.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    Where to a put the ground on antenna? Im using a mirror mount bolted on the inside of my truck bed with a spring then a 4foot firestick. I did a test, and I know the mount it's self is grounded. So do I still need to put a ground on the antenna part too?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If your on the metal already , and your bed is grounded to the frame , actually everything grounded to the frame and frame to battery , your probably good if the SWR's check out OK .
    The most important thing is for some metal to be UNDER the antenna , so it has a ground plane .
  3. fendereff
    fendereff 1/2 ton status
    Jun 24, 2005
    207
    Aggieland, Texas
    i thought it was real important to ground the antennas, but i had a buddy trying to convince me it didnt matter...what do you say pauly? i thought that the radio may not work properly and may actually damage the radio if it were not grounded. set me straight here...
  4. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    If you only key the mike while doing an swr calibration, without talking into the mike, you'll be allright. If you can't dial in the swr, then you'll know you might have a bad ground. The antenna itself does not want to be grounded, only the shield wire from your coax.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  6. fendereff
    Jun 24, 2005
    207
    Aggieland, Texas
    so much good info. thanks pauly. havent powered up my new CB yet, need to get me one of those SWR meters first. is it alright to leave the SWR meter hooked up all the time?
