questions on ditching all the air crap...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Nov 2, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    OK..
    Situation is a 1984 C-10 pickup...
    The carb is dead onit...
    has the air pump and all those dang lines...
    I want to put a edelbrock and holly combo I now have sitting in my garage on it but there's all these hoses running everywhere...
    Can i LITERALLY pull them all off ditch the intaje and old carb, and put the edelbrock performer and holly on it? What about the "pipes" coming outta the exhaust manifolds? what else do i need to worry about.. dont care about emmissions...
  2. Stylzz
    Stylzz Registered Member
    Sep 9, 2002
    95
    Mystic, CT
    As far as the switch I dont know but the pipes coming out of the exhaust and the air pump under the alt can be taken out without any problem. They are just there for emissions purposes. Just plug the holes in the exhaust with some brass fittings. There might be a pipe running down to the cat just cut it off at the cat and plug it up. It makes working on the vehicle a lot easier without that stuff in the way. You can do a tune up in half the time.
    Joe
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Whats to worry in Wa. State they don't open the hood for emissions test! At least not in Lynnwood! As long as it passes the sniffer, its all good!
    Bill
  4. reddog64
    Nov 9, 2000
    3,325
    so can i safely YANK all that crap outta there and cap the exhaust stuff and install a different int and carb then?
    Some one has to have done this???
    Anyone?
  5. GQ 350
    GQ 350 Registered Member
    Jul 20, 2002
    19
    Kelowna, British Columbia Canada
    /forums/images/graemlins/truck.gif I have done away with my air crap, what u need to do is use a cutter to cut each line right where they come out. Then pinch them off and use a torch to weld each one shut.
    That should help u out a bit I hope /forums/images/graemlins/rotfl.gif
  6. reddog64
    Nov 9, 2000
    3,325
    I guess I could use a set of exhaust manifolds that dont have the aire crap couldnt I?
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    That would be the neat way but I would go the easy cheap way, just take them off and plug them with a bolt. Brass is better like he said.
