Questions on Master Cylinders, Rear Disc Conversions, and 3/4 ton swappin'
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by IGOR, Sep 9, 2002.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Questions on Master Cylinders, Rear Disc Conversions, and 3/4 ton swappin\'
    I figured I'd get all my questions answered at once:
    First some background - I have a '72 K5 that I want to swap my '75 K20 running gear into. While I have everything off, I figured I might as well put rear disc brakes in. So from there, do I have to upgrade my master cylinder?
    The '72 Master Cylinder is pretty scary looking without the power boost - is it safe to use this master cylinder with rear disc brakes?
    Thanks...
  2. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    Re: Questions on Master Cylinders, Rear Disc Conversions, and 3/4 ton swappin\'
    I understand guys are getting away with using their stock master cylinder and running rear disks...
    I'll be trying it in a week or two myself... the only diff is my 72 is power brakes...
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    id say upgrade to power brakes would help a lot.second every one ive seen post about the conversion say there is no problems after running the same prop valve and all thAT.they say the brake pedal is a little squishy but the truck still stops much better than drums.
