Questions on reassembly of 208 transfer case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85chevy4x4, Aug 22, 2002.
  1. 85chevy4x4
    85chevy4x4 Registered Member
    Apr 26, 2002
    63
    kansas city, kansas
    I'm replacing my forks inside my trasfer case. I left the case on the truck and split it and pulled everything out. Which fork goes in first? Is it the range or mode fork? My diagram sucks and is hard to read in my book. There is also a spring that fell out of the case. Does it go on the rod in between the forks inside of the bracket? When I put it back together can I just use rtv gasket sealer or is there something better?
  2. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    I'm not sure what manual you have but go to a local library and get a "Motor" maual and it had a VERY good exploded diagram.
    I have a couple of copies at the house and I keep meaning to scan them in let me know if end up needing them.
