Questions on trans swap auto for 4 speed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85K5MT, Jul 25, 2001.
  1. 85K5MT
    85K5MT Registered Member
    Jul 22, 2001
    7
    Missoula, MT
    I've got a 85 k5 with a tired 305 and a almost shot 700r4, and the local trans shop wants $1300-1500 to rebuild to corvette specs which sounds good but I found a '79 3/4t with fresh GM goodwrench 350/4-speed(w/granny)/assuming 205 full time transfercase/14ff rear/and not sure on the front for $1800.
    Besides the obvious (drivelines, shifters, clutch pedal ...) are there any major problems that I would encounter.
    Thanks Chas.
  2. Neil
    Neil 1/2 ton status
    Jun 10, 2001
    275
    Dothan,Alabama
    cross member,hole in floor for shifter, no real problems making the swap especially if it is a whole unit(motor,trans) all together. That is kinda high price for stuff that old though.
    I would try to get a better price if ya can. Talk em down somehow.$1400 or so.
    Neil H.. Alabama.. '78 K5 400ci 4x4 AT,AC,PW Cheyenne. '74 C10 3spd/floor 250ci 4x2
  3. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    When I Changed From A Turbo 350 With A 208 On My 82 K5 To A SM465 With A 205 Taken From My 77 K5 I Had To Shorten The 205s Front Drive Shaft To Make To Make It Fit.
    The Front Shaft Was The Only Part That Would Not Bolt In
  4. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    You stated that the donor truck has a 205 full time transfer case. The 205 is considered a part time 4wd transfer case and the 203 was a full time 4wd transfer case. As far as the change goes it sounds as if you will have most everything you need to it with. The older trucks have a removable transmission hump that you could use and install in you blazer after a little modification to the blazer floor. I am in the process of removing my modified 700R4 and 205, to install a NVG4500 and 205 combo. It just takes a little research and time to get it all to work. Hope this helps.
    I may be slow, but I sure am fat!
