questions on transmissions
Discussion in 'The Garage' started by fatboy, Nov 27, 2003.
  1. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    one is what is this box for [​IMG] I have been told it is for my transmission. What would be causing my 400 to kinda stall when shifting from 1st to 2nd with pedal mashed?
    and then did a search but cant find anything on it. there was talk about running ford transmission fluid in the 400 for better shift quality I believe, or what about the B & M fluid Would like more info please. /forums/images/graemlins/burb.gif
  2. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    That looks like a Jacobs Ignition box from the picture, It has nothing to do with your transmission. As for running ford trans fluid, Type F it does have less friction modifiers but if your trans is slipping this will be a temp. cure if it helps at all. How is your fluid, when was the last time it was changed along with the filter? Has the trans ever been rebuilt? How are the fluid pressures in the trans, If you don't have the tools to do this find a buddy or a shop who does and look into the condition of your trans? If it is slipping it may be time for a rebuild. one of the bands or clutches is not holding. good news is a turbo 400 is cheap to rebuild.
  3. fatboy
    Jul 1, 2003
    290
    Tennesse
    sry not my coil but the black box next to it a module of some kind
  4. slider
    May 7, 2001
    547
    That is one I do not have a clue about. Do the wires run to the trans? Part of the electric kick down maybe? I know turbo 400's have an electric kickdown not a vacuum controlled one, follow the wires from the kickdown switch and see if they go to that relay then down to the trans. all the trans I ever had have been turbo 350's or four speeds so I won't be much help on this one. I am sure someone will have an answer to what it is but trace the wires anyway.
  5. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    esc box (electronic spark control), the plug has 4 wires coming out of it
    Pretty sure anyway...
    Rob
  6. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    Actually, now that I look it it a little closer, it looks bigger than my esc....Hmmmmmm /forums/images/graemlins/thinking.gif
    I guess trace the wires
    Rob
