Questions, Questions and More Questions
Discussion in 'Southeast Region' started by 79Stomper, Oct 30, 2006.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    All right. So the K10 is running now. However, comma, pause for effect....
    Numero Uno, hech
    It has a SUPER high idle to it. I have played with the idle adjustment screw on the side of the Qjet to get the idle down, but when I throw it in a gear, it idles down more and stalls out.
    So with this setup, I can put it in drive, idle to work and still be speeding. :rolleyes:
    Nay (neigh), duece, Dos,
    So now it is running, drove it to work this morning, got almost there and it starts mis firing like a champ. Pull over in a parking lot, shut ti down, and start looking for problems. All wires hooked up, none burnt from headers, getting plenty of fuel but doesn't seem to be getting any spark. Fast forward 20 minutes, try to start it again and fires liek nothing was even wrong. Any hints or suggestions.
    San or Tres
    Why is the sky blue?
    Naaahhh, but really. On the Q jet, where does the vacuum advance hose connect to on the carb? I have it in the one on the right side of the carb now just next to the PCV valve connection.
    TIA
    James, Jimbo, Jimmy, Jay, Jamz:eek1:
  2. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Sounds like a vacuum leak or the timing is off.
    -Harrison
  3. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Check high idle cam on q-jet make sure it's not stuck.
    Vac advance just needs full vac at idle the port no matter.
    Check spark control in distrubutor for eratic running.
    Sky is blue because the air on this rock is sphere shaped. :D
  4. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Where is this thing located at? I played with the little star screw that is spring loaded on the throttle arm and that is where I played with the idle to bring it down a little bit.
    Just keep in mind I am carb stupid.......
  5. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    :thinking: I bet if it keeps doing it you will have some sort of FI on it by the new year:bow: Sorry I caint help but you know I'm a idiot:doah:
  6. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    For now strictly a daily driver, well I have a 6" lift to put on it but thats it.....................well and some bigger meats but really that is all I am going to do to it. I have the other in pieces behind the house I need to put together.
  7. CB77GMC
    May 6, 2005
    771
    Heath Springs, SC
    It's sometimes called choke idle. Adjustment should be on the choke side on carb near base plate. Kinda a pain to get to I'll take some pics when I get off work. :D
  8. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Something else to check if your firing is speratic(sp?) anyway, the whole distributer could be worn out. Swap in another complete distributer. We fought with one with the same symptoms for a couple months. Changed every part we could think of in the ignition, distsributer, plugs, wires. Finally pulled out another distributer from my handydandy parts bin and that fixed it.
  9. CB77GMC
    May 6, 2005
    771
    Heath Springs, SC
    Pic of High Idle adjust screw
    High Idle cam
  10. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Thanks for the pictures CB
    I was out there looking fir it at lunch time today and I was close. I will get out there tomorrow and play with it some more and try to get the RPM down a little more. I fired it up today at lunch and fired fine the first time. Shut it down and really dids nothing started it back up and was missing like all get out. Went through and checked the plugs and they were soake dwith gas from running rich and or me flooding it trying to get it started again.
    You think the lifters will have anything to do with any of my symptoms. I am know to have them a little too tight.......?
  11. CB77GMC
    May 6, 2005
    771
    Heath Springs, SC
    Yes, Can and will choke down engine if too tight.
