Questions seeking answers
Discussion in 'The Garage' started by Fredbuilt, Dec 30, 2004.
  1. Fredbuilt
    Fredbuilt Newbie
    Dec 29, 2004
    4
    Virginia
    question number 1: how do you tell the year of a 350 chevy?
    second qustion if I do find a nv 5600 for my blazer where do how do I go about mounting it on the back of a 350 chevy?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Answers:
    1 - There is a number stamped on the back of the block(drivers side where the bellhousing bolts too)and also a stamp on the pass side front deck ledge. You can decode a block on www.mortec.com with those.
    2 - No idea
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have searched for a while out of curiosity , and can find bellhousings and adapters for nv4500's but not nv5600's . I would call advance adapters and see if they plan on one , or if one is available but isn't in their catalogue yet :xmas:
  5. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    Man, that NV5600 is one BIG transmission. :yikes: I'd hate to see what it took to get it under one of our trucks. :grind: :weld: :hack: :hack: :hack:
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    For a lighter (but still strong) 6 speed that should bolt up look for the ZF S6-650 6 speed manual from a '01 or newer HD pick-up. The Chevy's never got the NV5600.
    The ZF was the standard tranny behind the 8.1 and the D-max. The 8.1 should be the same bell pattern as a small block.
    I'm hoping to put one behind my 6.2 diesel. The closer ratios and overdrive would be a huge improvement.
    Rene
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Why do you want an NV5600? Dodge are the only guys that used it and only because of the mighty cummins. I would go for an NV4500 or the newer HD tranny like trusty said before I would try and bolt in that monster.
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    The ZF is only about 25 lbs haevier than the NV4500.
    Ratios are:
    1rst...5.79:1
    2nd....3.31:1
    3rd....2.10:1
    4th....1.31:1
    5th....1.00:1
    6th....0.73:1 (some sites list 6th as 0.76:1)
    reverse is 5.23:1
    It's burly enough to be also used in the medium duty trucks GM sells.
    Rene
