Queston on eliminating rear end sag
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Ressurection, Mar 26, 2004.
  1. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    I was planning on a 1 to 2" lift in the back to improve looks/stance on my 72. Originally looking at blocks but then saw 'helper' springs in Whitney. What are the pro's and con's to both situations? Also, Whitney for suspension parts-good or bad?
    Thanks!
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    The helper spring will stiffen up your rear springs. If your just wanting to level it off and 1 to 2" does it, I would just use blocks. If you were going to lift it, you would want to get a taller rear spring if that was affordable for you.
  3. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    If you add block just beware that lifting block on first gens won't fit if you still have square style U bolts with the anchor plate on the bottom of the axle tube....if it's round style U-bolt with the anchor plate on the top you should be fine.....you can make blocks work but its a lot of work to do it right....
  4. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Sorry, I couln't resist..
    I used helper springs on mine, it worked and was simple to do...
    John
