quick?? 10blt d44 same knuckles??? my knuckle still good??????
Discussion in 'The Garage' started by down4thakrown, Oct 9, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    would a 10blt knuckle work on a d44????????and is my knuckle still useable?????/
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    10 bolt knuckles wouldn't work on your axle since your tie rod goes in thru the top of the knuckle arm in the tapered hole.
    A 10 bolt taper hole only allows the tie rod to mount thru the bottom of it.
    In other words, the knuckles make the tie rods opposite of each other.
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    well that sux, would i beable to use a flat top knuckle on one side and a round top(i guess what u would call it) on the other??
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You can use either knuckle as long as both tie rod ends come into the knuckle from the same direction. The tie rod ends are the same as far as the taper is concerned so if your existing knuckles have the tie rod end coming in from the bottom and you have a knuckle with it coming in from the top you would have to use both knuckles coming in from the top and use your existing tie rod.
