Quick 14 bolt question: Hub gasket
Discussion in 'The Garage' started by scrappy88, Oct 19, 2003.
  1. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    The shim/gasket thing that goes between the axle shaft flange and the hubs on the 14 bolt FF, are they required? When I tore my 14 bolt down it had it on one hub but not the other. Just need to make sure before I put this back together. Thanks!
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    we didnt put them back into chevy4wds 14bff and it hasnt made any difference that either of us can tell..allthough it does leak a little gear oil since we havent sealed the hubs yet..
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Yes, unless you want a leak. If you decide not to use them then you will need silocone sealer in their place.
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Use 'em, you will not have greasy wheels. Get some gasket paper and use a hammer and tap your self a new gasket. Thats the easiest & cheapest way to do it.
  5. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    I was going to just leave them out and use a coat of silicone gasket sealer to seal them up. The original gasket I pulled out of it was just a metal shim type thing, so I don't see how it would have sealed without gasket sealer either.
  6. Confedneck
    Nov 1, 2002
    5,236
    either way, silicone or the metal gasket..both work..
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I didn't use a gasket on mine, just put some silicone on there. Works fine, no problems /forums/images/graemlins/thumb.gif
  8. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    yep just silicone on mine also had no leaks
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Don't waste your time making some out of gasket material or whatever. And don't waste your time with messy silicone either. Just go to your nearest Car Quest and ask for part number #J17829 and get 2 of them. Both of these will be around $4.00 apiece. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  10. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    whoo hoo finally I get a part # for those, mine have about a gallon of rtv /forums/images/graemlins/ignore.gif
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    Another helpful tip: don't dab on some silicone again. Buy a can of Permatex Copper Spray-A-Gasket, which is a 9 oz. high-temp sealant. Spray this stuff on both sides of the metal gasket and slap them on. Torque to spec and sit back with no worries of leaks again. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
  12. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    So $8 instead of 10 cents worth of silicone? My truck will not be so lucky /forums/images/graemlins/rotfl.gif Messy silicone, sheesh, what next take your truck in to get the oil changed so you don't get your hands dirty /forums/images/graemlins/grin.gif
  13. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    Yeah silicone it is. I figure I'll save the $8 and put it towards some quality gear oil instead. That was the last step in my 14 bolt rebuild. Disc brakes are on, detroit is in, and I'm set. /forums/images/graemlins/thumb.gif
  14. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Sounds like a nice set-up /forums/images/graemlins/thumb.gif
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    I prefer to re-install parts that originally come from the factory back into whatever I tear apart. Since the metal gaskets were there for a reason when they were built, I'm gonna leave them there. /forums/images/graemlins/ignore.gif
    As for silicone, which is the "poor man's fix" to using no gaskets, more power to ya! I don't mind anybody using them as everybody has their own preference. Just messier when the time comes you have to remove the shafts and clean up the bearing hub of the gunk. /forums/images/graemlins/tongue.gif At least with the metal gaskets, they will just come off and you can respray them with the copper sealant again and call it done. /forums/images/graemlins/ignore.gif
    FYI: I change my own oil, thank you very much. /forums/images/graemlins/ignore.gif
  16. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    everytime I replace the axles on our 5 ton internationals at work I only use silicone, never ever had a leak or was it real messy to clean the next time around, we usually throw away the gaskets since they end up leaking after a few hundred miles. I'm sure its the same principal with the lil' trucks
  17. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    How about the Fel-Pro part 55350, $1.99 at partsamerica.com (Checker, Kraguns, Shucks). I've used several of them and the quality seems fine -- plus you don't have to scrape the silicon off next time. /forums/images/graemlins/thumb.gif
  18. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I don't mind silicone, and I use a wire brush on the drill to remove the old silicone as long as I can do it withoug getting debris where I don't want it. Nothing wrong with doing it the right way /forums/images/graemlins/thumb.gif But I would have to get a new truck and start over if I am gonna do that /forums/images/graemlins/rotfl.gif
    LOL /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
