Quick 14 Bolt Question
Discussion in 'The Garage' started by 79Stomper, Dec 21, 2004.
  1. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I am putting my 14 bolt back together after 4 months or so of dis assembly so forgot something.
    On the 6 point nut on the shaft, how tight do I put that nut? I have one tight as can be and the wheel won'tmove. The other I have it snugged and the wheel moves fine so which one should I go with?
    Quickest replies appreciated as I am doing this right now.
    TIA:thumb:
    James
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    The wheel not moving is generally not a good thing....
    Go with the second choice:thumb:
  3. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    That is what I am thinking too, but I just want to make sure. Hate to be going down the road and smoke the bearings.
  4. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    I've always torqued the inner to 50ftlbs and then backed off 1/4 turn. The outer I also torque to 50ftlbs and then carefully tighten it until it lines up with the lock washer. Don't know if this is the text book way but it's always worked for me.
  5. 79Stomper
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Yeah, that is what I do for the front as well, But what about the rear? There is only one and it snugs against the outer bearing with a metal lock that fits in between the nut and the shaft then a lock ring goes over that.
  6. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    Eew... can't help on that one. I have the older style nuts (2 nuts w/ washer in between, like a front), I haven't dealt with the single nut/keyway set up yet.
    :dunno:
  7. readymix
    May 30, 2004
    6,706
    26
    You can switch to the 2 nut style. The D60 and 14FF spindles use the same nuts.
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    If ya can't find the spindle nut's I have a couple of extras if ya need em.:xmas:
