Quick 14 bolt question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Feb 8, 2001.
  1. CK5
    May 19, 1999
    21,626
    702
    CO
    What the heck are the adjusting sleeves (need correct name) called that hold the carrier in place in a 14-bolt called? Working on an article and need the correct name. I don't think adjusting sleeves is correct.
    TIA
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  2. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    Hey Steve,
    I'm looking at the diff parts diagram and I thinks what your refering to is called the "Diff Bearing Adjusting Nut", 2 required, one on each side. Someone correct me if I'm wrong but that's the only adjusting whoha that the diagram shows..
    <font color=green>Joe Angelicchio
    86 Jimmy 4+3, 35-&gt;39.5 tires,4spd
    </font color=green>
  3. CK5
    May 19, 1999
    21,626
    702
    CO
    Could be, here is a pic with arrows pointing to what I need the name of.
    Steve
  4. JoeAngelicchio
    Feb 18, 2000
    628
    That's what's in the diagram. I could tell because of the wire thingies that are called "Diff Adjusting Nut Lock". Hey when did you get a hoist for your garage?[​IMG]
    </font color=green>
  5. CK5
    May 19, 1999
    21,626
    702
    CO
    Cool beans, I just got the hoist in the mail the other day.
    Steve
  6. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    wow i cannot wait to have one of those!
    baja surf nazi
  7. Steve,
    Are you doing your own re-gear or having a shop so it. Hmmmm let me guess, you have it at a shop and you are watching/helping him do it while doing the write up and pics !! Am I right? Let me know how those 4:88.1's are with a 700R4.
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
  8. CK5
    May 19, 1999
    21,626
    702
    CO
    Burb, you got it, it was at a local 4x4 shop to have it re-geared and I should have the tech article up tonight. IF I planned on keeping the 700 and small block I would go with the 5:13 gears. I plan on a big block with a 400/203/205 combo so the 4.88's are what I went with.
    Steve
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    My service manual lists those pieces as "side bearing adjusting nut". I have heard of adjusting sleeves also. Guess everybody has a name for something.
  10. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    NICE LIFT. Lucky Dawg.
    Durant, Ok
    I love my SAWZALL!!!
  11. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Why don't you include in that article, and the FAQ :Define Pinion Bearing Pre-Load ?
    Please
  12. CK5
    May 19, 1999
    21,626
    702
    CO
    pinion bearing preload is measured in inch-pounds, and is a measure of the rolling resistance of the pinion bearings after proper torque has been applied to the pinion nut.
    I have added this to the article, but keep in mind, I did not want to get supper detailed and end up with a 14 page "how to" that no one would read, I want to show the major steps and why it is a good idea to have someone qualified to do this.
    Steve
  13. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    Steve I just read it and it ansewer a few of the ?s I had about a re gear a if I could do it my self.
    thanks for the info I got to do something about thes 2.73s
    [​IMG]Hail To The King
    <A target="_blank" HREF=http://www.trailblazer90.coloradok5.com>http://www.trailblazer90.coloradok5.com</A>
  14. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    Steve, this is unrelated but I thought you might have some insight. Where would be a good source to obtain the 13 inch backing plates from the 14 bolt SF needed for the FF conversion? Most the junkyards out here in Utah dont seem willing to part with just the plates themselves. What are my options? Thanks
  15. CK5
    May 19, 1999
    21,626
    702
    CO
    You might try car-part.com
    online salvage yards
    Steve
  16. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Swap to discs. TSM sells a kit for about $250 I think.
    -- Mke
  17. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    why do you need to change out backing plates on the ff? i have a 14 bolt ff my self and am getting ready to do an axle swap this spring. let me know.
